2N starter relay
kldenny01
I have oil leaking from the starter relay. I have gasket material to make a new one. Have looked at F04 manuel. When I pull it off how is the push rod from the push button connected? :?: :?:
(quoted from post at 10:07:00 05/16/15) I have oil leaking from the starter relay. I have gasket material to make a new one. Have looked at F04 manuel. When I pull it off how is the push rod from the push button connected? :?: :?:
od is NOT 'connected' to the start switch, it just touches it.
(quoted from post at 07:26:37 05/16/15)
Thank you JMOR now I can fix that leak and then move on to the water pump. Gotta love these old machines. :D :D
