What Do I Need to Order?
I posted a few days ago about being able to move the left wheel on my 8n back and forth while on the ground. I initially thought it was the wheel
bearing but when I finally was able to check it this afternoon the wheel bearing was fine just gunked up with old grease. The problem was the bearing
in the spindle or what was left of the bearing. I have looked on our hosts parts page but did not see any bearings for the spindle and on some of the
other parts stores I see bearings, bushings, and seals. I need some advice on what to order so that I can have everything I need to put it back
together.
I think I replied to your first post too, but if you jack it up,
can you rock the whole spindle from top to bottom?
If so you may need new bushings like these.
Check out New Holland's parts site here and compare to where your's moves.
I did jack it up took the hub off and checked the wheel bearings first when they were fine I checked the spindle and it moved freely. When I knocked
it out the bearings fell out on the ground, so I am pretty sure that is why the tire was rocking back and forth. Thanks for the links I will check
them out.
im going through the same thing , im ordering the bearing and the seal , i have the bushings . im going to do both sides while im doing it its not that much work and i will know im good to go.
