Well I cut a wrench to fit and removed the N's relief valve. New valve and old valve.
Looks like plunger is still in pump. Tried the wife's tweezers and not sure I ever grabbed the plunger shaft. Think I can feel it wobble/rotate with the dowel. Was able to stick orange belt checker all the way into chamber, but red tube bottemed out and I cut the tube to show depth to you guys.
Can I backfeed compressed air thru test port and blow out the plunger? I'm sure it is not in sump of pump.
Cut away pics and all comments apprieciated.
