My 8N threw a fan belt, overheated, and now I have bearing chips in the oil. I've already put too much time & money in this tractor and just want to get rid of it. Tire are very good with one new rear rim, tube, painted, filled with Rim Guard, and new wheel bearing . New tubes in the front tires and painted rims. Front pivot pin, king pin bushings & seals, and front wheel bearings. Axles painted. New points, condenser, cap, rotor, and coil - 2 hrs. run time. Radiator has been repaired, cleaned, and pressure tested. Carb rebuilt. Engine was rebuilt in 2006 but had less than 200 hours before it trashed. Replaced the clutch disk, pressure plate, pilot bushing, and throw-out bearing at that time. PTO shaft seal & oil pressure gage. Have a new Fel-Pro head gasket and new head bolts. Only painted parts that were repaired not the tin. I'd rather sell the tractor to someone who is into Fords rather than part it out. Tractor is in northern Wisconsin.
