Lift arm yoke - too bent?
tburch
What would you do with this? Bend it back? Leave it? The left one is straight, and the right one seems to have suffered a collision at some point.
And, the rear left lift arm has been welded too - I reckon it is fine, in the scheme of things.
Thanks, Todd
I would leave the bent arm alone. They are hard to remove. The welded arm will work fine. Easy to replace if the esthetics bother you.
I heated mine with a torch a few years back and bent back into position and still working fine. Heated slowly over a large area . Was not as bad as yours.
I wouldn't bother trying to bend it back, I doesn't look like it should cause any lift problems.
As far as the welded lift arm, that should be fine too. You could also use it as an excuse to buy aftermarket lift arms that adjust like a toplink; makes hitching up to heavy implements a little easier.
