Ok so I rebuilt my engine in my 49 8n about 10 year ago. I did not do the oil pump I know I should have but I just didn't so thats that. I didn't replace my oil pressure relief valve and spring either. Just like most everyone else I have 30 lbs cold and around 10 hot.
I got my new spring and plunger today so I takes the old one out and on visual inspection they are both the same length but the old one seems to be a thinner steal so i gave it the squeeze test. hmm much lighter. so I got out the wife's kitchen scale and with the old spring and plunger it took about 3 lbs to compress it until the plunger bottomed out on the scale. interesting Hmmm.
the new spring and old plunger( I used the old plunger in the test so the spring was the only difference) it topped out the scale and still had room to go. I think the scale tops out at 5 lbs. So it probably takes 6 or 7 lbs to compress the new one down.
Well that got me thinking I wonder if the tension n the old spring changes when it heats up, I figured I would spare the wife's scale from the melty circles caused by my silly experiments. I am going to say that weather or not it does is irrelevant because it was bad eithr way. It will be a week or 2 before I get it all back together(paint, rewiring general cleaning). what do you think the chances are that I start to see 40 lbs cold and 20 or better hot once its all back together and what is your experience with oil pressure and the relief valve?
