I like my Tractor
New User
52 8N side mount distributor;
New battery, 12 volt conversion (alternator, bracket, harness and resistor), plugs, wires, cap, rotor (yes, it's on ), points and condenser. Still using 6 volt round coil and 6 volt starter. I also installed a new fuel bowl assembly, fuel line and rebuilt the carburetor.
It had been running great last few days, however I had not put it to work yet. It started without the choke almost instantly in the morning and even quicker after being warmed up. I was so proud of it I went and put on a new steering wheel and an exhaust pipe with a new clamp and hanger.
After replacing ALL the bolts and tightening up the 5' brush hog I was ready to get to work. I hooked it up and drove it about a half mile up the road and back - without the PTO hooked up. Had a little work do on the hog. The hydraulics appear to be weak and sluggish. I expect draining and replacing the hydraulic fluid is next, but that's for another day.
When I got it back to the house and fooling with the lift at a medium idle (hog still attached-not hooked to PTO), all of a sudden it started running bad. I couldn't tell if it was missing or choking or what. Pulling on the choke made no difference but opening the throttle more seemed to help. I shut it off and have not been able to start it since yesterday.
After turning over excessively with the choke pulled I can get it to fire once then the starter kicks out. Surely the hydraulics don't have anything to do with it? I took the hog off completely and rolled the N away.
Points are clean and working properly. Ignition on, points open I get 12 volts between distributor side of coil and ground.
I am thinking something has happened with the carburetor. I've noticed gas weeping around the idle mixture screw and mating screws. Not dripping, just weeping.
Could it have jumped time?
Let me know what you think. Exasperated
