I'm thinking my starter isn't spinning as fast as it ought to… or could. But, my reference to saying my motor turns over slowly is based on my experience with 12V auto engines turning over and their typical speed with a fully charged battery. I've not had this tractor running since I bought it, so I don't know it's behavior yet.
I ask this question as my tractor is still in a state of waiting for more parts before I actually try to start it again. My last attempts at starting were halted when I found about a pint of water in the starter. I removed it and took it apart. Lots of rust, so I used emery cloth to clean the highly rusted armature. I did not take it back to pure shiny metal, but only to "this should be good enough to work".
The field coils inside the starter casing had a lot of torn insulating tape, but I'm not sure that plays a factor or not.
The brushes have plenty of life left in them and the springs were tight.
I had a 6V / 12V charger/starter hooked to the battery (6v mode, obviously) as I turned the engine over after reinstalling the starter, and it spun pretty slow. I would guess it spun the motor around 1 revolution per every two seconds, or there abouts. In my mind, nowhere near fast enough to create a low pressure to suck air/fuel into the cylinders.
I'm considering taking the starter out again, and apart, and hitting the armature on my high speed fine wire wheeled grinder to clean it back to pristine. Am I going in the right direction?
Thanks Todd
Thanks Todd
