Tranny input seals
If your countershaft bearing retainer cap is leaking get two gaskets as its the same as the one on the input shaft. May have to drain the oil to replace this gasket. Also some alternate seals numbers:
SKF 13568
National 480570
So gunked up in there hard to tell just where coming from but will investigate more before motor is installed.
Thanks for heads up Jim
At least clutch not gunked up
