I painted the script last night. Forgot the good paint brushes at home so I used my daughters cheap Crayola paintbrush. Practiced once on a different hood and it went good. Sat down with this hood and Was instantly nervous. Though it turned out good! Probably took me 20 minutes per side. Mark made a new wiring harness copied from the original that was on it from the factory. Fit perfect. Even managed to get all the wires down the tube. Got the new steering wheel on and the radiator is now on. It had this probably original (first thermostat it ever had) in the hose. Replaced it and will see one day if its still good. Got the new steering wheel on. Its the first one we've ever replaced man are they nice. All that's left is to fix the valve on the sediment bowl and put the gas tank back on, fill with coolant, add hydro fluid, and put the hood on and should be ready to fire up. Will take some pics of it out in the sunlight when we're done. I opted for black lift arms on the back, I like the little bit of contrast. This tractor didn't come with them so they needed painted anyhow.
