Got my tractor back and wanted to mow. Problem hard starting. After charging batt. checking spark, found temp carb from TSC was flooding. Solution put rebuilt carb back on. First try it fired but failed to catch. Second try three rev fired and never looked back. I was amazed at how well tractor runs, from dead idle to full throttle no miss no back fire. Mowed for 1 1/2 hours,took short break tractor started on first try. This morning at 48 degrees one try with no choke up and running. Can not THANK YOU enough for the great work on the carb. One small bone to pick if you look at attached pix your work makes me want to paint the whole tractor to look as good as carb.
