Distributor - Front Mount. Gasket Glue??
Thanks Soundguy....always a great forum. And...a fast answer too...now back to the shop to finish up.
I have found that rubbing a dab of oil along the gaskets between coil & distributor and cap and distributor help to keep out moisture from heavy rains. My N sits outside most of the year.
Colin, MN
4 (four) front mount gaskets come in the pkg for my '48 8N distributor. Where does the "Cap Gasket" go? (The thin-narrow round one). I tried to add it to the distributor but then it wouldn't let the cap seat to the distributor body (Where the points and condenser are.).
(quoted from post at 12:57:21 04/26/15) 4 (four) front mount gaskets come in the pkg for my '48 8N distributor. Where does the "Cap Gasket" go? (The thin-narrow round one). I tried to add it to the distributor but then it wouldn't let the cap seat to the distributor body (Where the points and condenser are.).
Just a dumb question. Did you remove the old gasket or o-ring from the outer groove in the cap. Is the old gasket stuck on the Dist housing.
I prefer using an o-ring over the cork gasket on the cap.
