Billie R. Smith
Ran fine when I parked it just before winter,now it wont start.I had everything on hand for a tune up so I started there. Points,plugs,rotor,condenser,and a new coil just in case.I did not replace the distributor cap.It looked fine.Plug wires are fairly new.I removed the gas valve and screens.they were clean.No crud. Tank looks nice and bright inside.Blew out the gas line .removed the carb and flushed it out with kerosene and aerosol carb cleaner. Carb is getting gas. Motor turns over fairly strong and continues to do so until the battery start punking out.It just wont fire.I set the dizzy up according to the ITT manual.Got a bit confused on the need to set the timing with the 2 straight edges cause it seems to me the dizzy can only go in one way and the shaft has to match up with the slot on the camshaft.Am I suppose to top out the number one piston first ? I know the Firing order is 1243 but are the cylinders 1234.Just curious if I got the wires back on correctly Number 3 on the dizzy is no.3 cylinder .right.Almost forgot.I broke the copper strip that joins the condenser to the points co I replaced the entire plate with the points and such already on it.Set the points to.015 also.
