Looking for a 2.5ohm 50W resistor...
...Anyone want to get rid of one? Need it for a small project I am working on. Dont care if its ceramic, metal can or open wire wound.
If so let me know how much you want for it. A small envelope and a few stamps should cover shipping.
Have looked at a few places but shipping cost is twice as much as the resistor.
May run up to radio shack to see what they have.
50w is plenty of dissipation, look for this to be aluminum cased with heatsink fins.
U wouldn't be looking for a CSI resistor for an I/o engine would you?
Marine supply places sell them, but cost is 30-40$ due to the power dissipation. Ratschacke usually has 5-10w ceramics.
Cdi-121-br50-2.5. Should be a good part number.
For wire wound flat, 55w, 2.5ohm # (rwf) hl55-2.5. 7$ from surplus sales of nebraska
(quoted from post at 14:09:07 04/24/15) 50w is plenty of dissipation, look for this to be aluminum cased with heatsink fins.
That is one of my go to sources for parts but their shipping is a bit high for a single small part like that.
The resistor I need s/b the same that folks use when putting a 6v square can coil on a 12 volt system.
I saw one in pep boys yesterday for $25 but passed.
Maybe I am assuming incorrectly. I thought those white ceramic resistors that you put in series with a ballast resistor are rated at 55watts?
Like adult underwear, it depends on which ones you buy.
People shopping at RadioShack are likely buying 5-10w jobs.
10w2d7 is a 2.7 ohm 10w rs resistor. If you need 2.5 on the nose, series a 1 and a 1.5 10w... etc..
(quoted from post at 15:16:31 04/24/15)
talled, points closed, maybe 55W, but the average current with engine running is much closer to 1 amp than 4.5 amps. Or about 3 or 4 Watts.
Thank You both for the input. I was going off of constant max current rather than normal current draw.
I need to protect the coil and points on a test jig I setup.
Using a 12volt battery connected to a 6 Volt round coil. Coil has a 1.1 ohm reading. So adding a 2.5 ohm resistor in series should get me to where I want to be with about 3.6 amps.
Try junk yards. Some older cars, used ceramic resistors in start-run. You may have to put some in series to get 2.5 ohm. I bought mine at compatetion antique tractor site. I run 12 volt generator and 6 volt coil on 2N. Have a 12 to 6 volt ceramic dropping resistor and ballast resistor in series. 4 years same points and coil, with fast start and positive ground.
Charles Krammin SW MI
When I set those up to test I use a VR1 voltage reducer and the appropriate resistor for the coil...
VR1 is a standard number for NAPA are most parts stores.
Have you considered using a auto headlight switch?
You could wire it through the dash light dimmer circuit(rheostat)
it would be adjustable.
Don't know if it would get 50w though.
Quick run to RadioShack and $5.19 later I picked up 2 one ohm resistors rated at 10 watts and a .47 ohm resistor rated at 5 watts. Connected them in series and ohmed out at 2.6 ohms.
Perfect.
Wanted to get 3 eight ohms resistors rated at 25 watts and connect them in parallel but they only had 2 left.
"AS pictured", that is a 20 Watt resistor. Needs 291 square inch heat sink or equivalent to be rated at 50 Watts.
Thanks.
Brass plate that the jig is mounted on is a 12"x12"x.25". It will have to do.
Not to mention, I doubt I will draw more than an amp or two at any given time while testing unless I forget to hit the off switch when I walk away.
Now if I can only find my 30 year old pint size paint can of heat sink paste.
(quoted from post at 14:09:19 04/29/15) Thanks.
f can't find HS paste, just put some bacon drippins under it & it will smell good during testing. :)
