any info on 2n lift problems
yardman1000
New User
changed hydraulic oil in lift and now it takes for ever to lift i took side plate off but i see no leaks from the piston was wondering if control rods hsve come off the T control vslve or maybe relief valve is open,i do not see any violent oil splashing in fact see very little ripple in oil probably caused by pto shaft revolutions any suggestions would be appreciated i would think i would have to drain oil to attach the contol rods and also take off both inspection plates to do this and or replace relief valve thanks for any info on this problem
It could--check it by slipping piece of clear tubing over the end of the valve-if the tube fills up with oil it is leaking and needs reolaced..
control valve is probaly sticking
Lots of times the trouble with a sticking control valve is that the spring that connects between the middle flexable section of the control rods and
to the front end of the ram cylinder is weak. Take it off and shorten it.
Zane
