no oil presure
Hunterjcw
New User
I changed the oil in my 8N after it sat all winter. I used a synthetic blend the oil pressure never cam up. I pulled the pan and can't seam to find a problem. What happened?
Did you try priming the oil pump? There's a big nut/plug on the
front of the block you can pull and put oil down to prime it.
If it's a front mount distributor the plug is right by the distributor.
Don't loose the spring and plunger that are under it!
There are quite a few how-to's in the archives here on YT that
talk about priming that pump. Not uncommon and probably not
hurt at all as long as you didn't run it very long.
(quoted from post at 18:29:17 04/23/15) Did you try priming the oil pump? There's a big nut/plug on the
I did run it long enough to tighten it up but it moves with a bar. Hopefully I can losses it up enough. I will look for the port thank you. Wish me luck. The pan should be fun to back on too.
(quoted from post at 21:34:46 04/23/15)
se a a queeze bottle with small hose & try to get a cup or more in there & don't be afraid to make a mess or you won't get enough in there to do any good.
After JMOR coached me on how to prime, I used a simple pump to prime my N. The hose fitting fit perfectly and didn't spill - it was too easy. Good luck.
(quoted from post at 19:40:30 04/23/15)
Great photos thank you. Back in my car repair days we would pack new or rebuilt pumps with petroleum jelly. Do I need to do that? I can't find a R&R
(quoted from post at 20:08:55 04/23/15) I changed the oil in my 8N after it sat all winter. I used a synthetic blend the oil pressure never cam up. I pulled the pan and can't seam to find a problem. What happened?
I have an old 8N that is really tired . It will lose the oil prime if it sets for a day or two . I installed an air valve in the 1/8 npt drain plug on the oil filter canister . Before I start I usually need to add a quart of oil , it's tired . I check the fluids and tires .
I hit the air valve and blow oil backwards which seem to work on this tractor to prime the pump . Before the motor would rattle for ten seconds before the pressure came up . Now it does not rattle and the pressure comes up once started .
I was going to install a shut off valve inline going to the governor to keep oil from blowing that direction and make sure I have enough volume to prime the pump . Seems to be working with out the valve . I have done this 5 or 6 times so far on one motor so I don't know how well it actually works and it is blowing dirty oil into the system which is not a problem on this motor .
http://www.ebay.com/itm/Milton-S684...m5d55a375fe&item=400868734462&vxp=mtr
