I'm starting a new thread because I think I have a new issue. Following my head gasket replacement, the engine is running significantly worse. I did check the cylinder compression and it actually improved from what it was before I removed the head.
1. 110
2. 105
3. 100
4. 100
My current symptoms are:
Hard starting
Stalling at idle and under load
Oil pressure is lower than it used to be at idle, it's fine at higher throttle (40psi) but it's 20 psi or less at idle - before it stalls that is.
There's also a LOT of popping and cracking which seems like it's running too lean.
So there's clearly a loss of power, I'm not sure if It's due to the head gasket job or if my carb or dist decided to turn on me too. I rebuilt the carb and the distributor last August but I've heard that the Tisco points I bought are poor quality and don't last long. Any thoughts on where to start based on these symptoms?
1. 110
2. 105
3. 100
4. 100
Hard starting
