Hello folks,
Im hoping to get a bit of help here on this tractor.
First I will say what I don't know if its a 2n 9n 8n. I bought it recent and no visible numbers, I know it has fergason on front plate. Forgot the year the guy said it was
I am new to the whole tractor seen to.
No the problems:
It was running and starting fine, then one day I shut it off. Then it would do absolutely nothing. Even hand cranking wont do it right away. I put the switch, hold the clutch down then hit the push button, and Nothing like nothing had power. Starter would not turn engine would not crank or anything just a slight hum.
So I replaced the battery - Then same problem, so I rebuilt carb and Starter with new bendix drive. I can occasionally get it started by leaving the battery charger on for a few hours then hand crank it and it starts. Rebuilt start just now seems to start engaging but still wont turn over. (possible spark issue?)
Anything you can suggest to check out, or think what it could be please throw that list my way have gravel to move.
Now question about the starter switch.
Its weird to me like it screws downward but goes to empty space?
Similar to this photo:
I cant find one anywhere to replace so is there a way or different push button I can install or use?
Thank you everyone for your insight and suggestions (God knows I need them)[/img]
No the problems:
