Tall T
It seems to me that undoing the 4 bolts holding the gearbox to the deck, would let the gearbox and blade assembly drop down
so that I could just lift the deck and pull it all out from under.
If I put the whole thing on its back, all the lube will drain out
whereas I can keep all that under control and have an easier time of removing the blade bar and changing seals.
Any reason I shouldn't do this?
I don't think there are any bolts coming up to the gearbox from underneath.
Oh and did I ever mention how Amsoil MP cuts rust instantly?
Then I sprayed the input shaft end and the MP took it all right to bare metal without any rubbing and the rust pouring off.
