BlackThumbHomesteader
Spent today using my rear bucket to knock down the Killer Knoll(was 'hogging down 8' high grass and hit solid ground that rose up 4' and nearly flipped my 2N over) and I've found that unless I have the top link adjusted to a length that makes for poor scraping with the bucket the lip ends up grinding on my ORC. I had the same issue with running my plow and having the right most coulter bump it a few times.
I'd rather not have to knock the pin out just to switch an implement and would like to hear some opinions on a quality push button ORC brand and source if possible.
Edit for information; 2N, 1-1/8 PTO shaft, ORC with 1-3/8 end already installed. I have no 1-1/8 implements.
