Lift arms will not go down far enough for my box blade.
Braxmaier
Just picked up a box blade and my lift arms will not go down far enough, please tell me it's a easy fix, 52 8n, thanks.
Braxie........look under yer right knee, see the handle? It ain't fer flushing, its fer selecting position ...or... draught (draft) control as in plowing. Lever UP fer position and lever DOWN fer plowing or draggin' a blade. Simple, eh? .........respectfully, Dell
BOOM !!thank you, boy once it's in that position it sure takes some getting used to, up down, up down, she will creep up you if your not paying attention, I also picked up a dearborn plow, I will take some pics later. Thanks again. .Brax.
One other problem I have with the box blade hook up, is if i have the leveling arm box on the right side cranked up some...it holds the arm at that level and won't go on down to hook the arms up to the box blade pins. I forget it occasionally and finally realize that is what it is and turn the handle enough to drop the arms on down. It won't let the arm on that side drop but so far until I crank it back to the correct height for hook up.
