2N Grill Removal
Retcol
Is there a way to remove a Ford 2N grill without damaging anything? I can see there are some pins at the top but I don't know how they are removed.
Some just un clip,some have bolts in the bottom so the top unclips and swings out to clean the radiator.And some are bolted in good to keep from falling out and running over them with a dick or bush hog.
Take a screwdriver and pry the pin(s) down at the top of the grill so they no longer are in the hole. You will need to pry the grill forward while prying the pins down. Once the grill is loose at the top, swing it down. There are two bolts at the bottom and you need only to loosen one. Spread the lower hood panel and the bottom of the grill will come loose.
3 pins at the top and 2 bolts at the bottom, one on each dogleg.
