Front end loader valves (replacements)
Mtt2961
New User
Hello, I have a 49 8N that came with a new idea- horn loader. I need to replace the two valves that lift bucket up and down and also tilt back
and dump. Can anyone give me advice on what to buy to replace what I have and where to buy? I have pictures but don't know how to upload.
Thank for your help.
Mike
When I replaced the loader valve for my tractor, I called Surplus Center and talked to one of the guys there that was familiar with hydraulic systems. He asked me questions about my set up and the pump I was running and recommended a valve for me. I ordered it and it has worked perfectly. It was not an identical match to the previous one, but after drilling one additional hole where the valve mounted, it fit and worked properly. I would definitely give them a call.
(quoted from post at 20:37:41 04/15/15) Hello, I have a 49 8N that came with a new idea- horn loader. I need to replace the two valves that lift bucket up and down and also tilt back
Mike
Mail me a picture or two and I will see if I can determine exactly what you have.
[email protected]
Here are some possibilities. The top one should work if your pump is 8 GPM or less. The 14 GPM one is overkill unless you have a bigger pump. Both have two DA spools so if the lift cylinders onyour loader are single acting you will need to plumb the extra work port back into the return line.
[u:7c75638098]Prince 8 GPM Valve[/u:7c75638098]
[u:7c75638098]Prince 14 GPM Valve[/u:7c75638098]
Personally for loader work I prefer a joystick operated valve and the incremental cost is not real great.
[u:7c75638098]Walvoil 12 GPM Joystick Valve[/u:7c75638098]
TOH
