yardman1000
New User
I ha the lift working very slowly and it would leak down in about 1hr after shutting off tractor i checked pil and it needed changing bad so i did that adding about 51/2 gallons of fresh oil for ford 2n tractor now the lift comes up half way very slowly but it does not leak down at all when tractor is off the control lever does feel like it does not have tension on it when you pull on it it moves very easy so wonder what would suggested checks be i thought maybe replacing relief valve and checking control lever was wondering if relief valve can be replaced from sideplate if so does someone have procedure to do this and also procedure to check friction disc and replace on control handle,i rebuilt the engine but the hydraulics are new to me on ths old tractor but she runs good,any information on above would be appreciate
