Hey guys need a little help Have a 1952 ford 8 N trying to get fixed up adjusted etc so I can move on to paint ? I removed
rear wheels brakes look good all brake parts look good siting on tractor right rear brake adjusted good pedal returns like it
supposd to Left rear on the other hand is giving me problems I have a good Brake on that side the problem is pedal will not
return I greased where pedal goes through trans houseing I guess that works with clutch pedal I don't no Now when I push
down on clutch pedal brake pedal will not return if I was to push on brake pedal while tractor is moving brake pedal will
return as long as I don't push down on clutch brake pedal returns just fine is there another adjustment some where for pedal
return Thanks for any help
