Well probably not the first time for the tractor but it is for me. I have a ferguson 2 bottom (and a 3 bottom thats missing a share) I had to de trash a field and the ground was thawed enough so I used a cultivator to scrape off the bits of wood and some old tarp and things that were stuck in the ground at this spot and the ground is soft enough everywhere now that I can plow it for gardens. The 2 bottom plow seems to suck into the ground properly and the 2n seems to balance it right as it's slicing through but the opened furrow is just dropping closed again after I go through. Is this because I'm going too slow? or is there another setting, It seems like it's working smoothly except for the slice falling back down. maybe it should be angled more? This was on my first and only pass. I thought I'd only have tome to scrape off the junk but got to play with this as well.
One other, silly question. Should I start from the middle of the field and sot of make parallel passes from the middle out until I get to the outsides? seems like a lot of dead heading doing it anyy other way
