Quick Hitch
Fuddy Duddy
Got these at an auction. Bout all I can find by google is that they are some type of Quick Hitch. Maybe even that you can hitch up with out
getting off the tractor. No one at the auction knew anything about them. I took the chance and got them for $7 each. There was a third one
like the top one but missing a few parts that this one has. So I let it go. next bid for it went for $5.
Anybody use one of these? Know what I might need to make it work. Went to www.freedomhitch.com. No help there. Best I can figure is
these mount to the tractor. Then you need an adapter for each implement.
Try THIS LINK and then in the links in the left column of the page, select Owner Support. It should take you to a page where you can download Specifications and Service Manuals....
If you have problems, let me know. I downloaded them all....
Mike
Thanks, that helps.
Been often said you should have a tractor for each implement. Seems like this would be a cheaper way to go. Guess you still have to climb
down to hook up PTO driven implements. But this looks to be the way to go.
