James Hill
Update, lift goes up, immediately falls, doesn't start lifting until 3/4 way up on pull handle, after reading here, the fo35 manual I finally figured
out. How to adjust the lift by loosing the four bolts on the lift arm lever, and pushing it either forward towards the motor, of aft towards the pto, in
my case I had to place it all the way back towards the rear position, lift now starts going up as you pull the handle, and holds when it reaches
the top. Thanks everyone for all the help.
