greywolf224
Installing a new set of Blue Streak Points on a front mount.
Makes me wonder if I should'a went with the china made ones.
Had to bend the stationary point back and than twist it forward to get to line up vertically with the point on the rubbing block.
Then had to put a copper washer under the rubbing block to raise it to the height of the stationary point.
Lastly had to file the top of the rubbing block down to get the cotter pin to fit.
Best points I have used yet are ACDELCO F121
