KCTractors
- Location
- Central Wi
I am replacing a bad axle and seals (Threads were stripped) with a used axle from E-Bay and a used hub from John Smith. Both look very good, when I adjust the bearing load, the axle will turn with no effort and one side will turn the opposite way like they should . When I tighten the hub down on the axle I cannot turn the axle without a bar. The hub still has room before it goes on to far into the axle splines. I put the old hub on and does the same thing. The opposite axle will not turn with hub installed, loosen the hub and everything turns as it should. What am I missing. I must have changed a couple of dozen of these hubs and seal without any problem.
