Patina488n
Had enough of the 3 point brake system (drop the blade)
Rear seals and brakes
1 wheel off and it looks likes new hubs will be ordered tomorrow,
I did find 2 steel shims between trumpet and brake backing plate,
I think there is just supposed to be a paper gasket there,correct?
And 1 steel shim and 1 paper between bearing and race?
I know I can figure out the preload,just wondered if the 2 steel should be replaced with just paper gasket and a touch of sealer?
