8N Leak down
MilkMan75
New User
just bought a 1950 8N runs good everything seems to work but the arms in the back will go up but leak down works more hydos what is a good place to start.
Remove the right inspection cover (has the dip stick in it). Run the tractor and raise the lift. Observe with a flash light. If you see oil
dripping down from above, the oil is leaking past the orings in the ram cylinder. Strongly advise getting the I&T FO4 manual before you start
to fix. A good idea to replace the pressure relief valve while you are in there.
" the arms in the back will go up but leak down works more hydos what is a good place to start. "
Tip # 16 at the link.
" just bought a 1950 8N "
See tip # 39
75 Tips
