My last started my front mount 8N 4 years ago. Surprised it started and only ran it long enough to move it around the lot. The oil pressure junction block was stripped between the gauge and junction block and had been plugged.
I did change the oil & filter 4 years ago when last started and less than 20 minutes on new oil.
Also has trans fluid in crankcase from unsticking rings.
Under my watch, I have installed new , oil pump plunger spring, oil pressure gauge, oil pipe from new Junction block, 12 volt conversion kit, ammeter, harness, plugs, coil, used dizzy from John Smith, new head gasket, carb that Gary rebuilt and new exhaust clamp, refaced exhaust manifold and lots of cleaning. Also have a new radiator, hoses, $23 thermostat.
Going to rig up a lawnmower tank and start before I replace the hood, tank and doglegs.
I primed the pump with a squirt of 90w and turned over the engine w/o plugs watching the oil pressure gauge - gauge never moved off of 0.
Would you guys start it and watch gauge for pressure ot take other action?
