Crispy has a new axle pin (pic)
Royse
Not much other progress, just LOTS of cleaning.
(quoted from post at 05:49:25 03/22/15) Looks good,
What is the proper lube for this bearing/pin?
I would say none, grease attracts and hold grit. Better dry in my opinion.
(quoted from post at 16:57:16 03/21/15)
I hear opinions on both sides, but I put the bushing in dry too.
If I'm not mistaken I think someone said the factory did also?
I do use a little anti-seize on the bolster bores.
I have not read anything on a proper lube for this
bearing.
But it makes a noise sometimes, so I spray it with
graphite, noise goes away, not suppose to attract
dirt.
But who knows??????
Sure do not want my new bearing to wear out again.
