One of these things is not like the other one.... (pic)
Royse
I'll have to tear them apart to see what's going on.
Neither one is loose on the bearings. :shock:
ARE those off of crispy I don't recall what model tractor crispy is but I see the grease fittings are they factory or po. additions. On boat trailer axles there is a vent so as not to over pressure the grease and pop a seal out.
Yes, they're off Crispy. It's an NAA.
As far as I know the grease fittings are added.
Probably not a bad idea other than getting busted off.
"Thrust bearing looks bad too."
Good eye Shaun, the thrust bearing is definitely gone. Actually,
all the bushings in the vertical parts of the front axles are gone.
[b:56537c9f8f][i:56537c9f8f] Looks to me like, the hub plate is thicker, where the lug nuts go through........WHY......Left vrs right variation???????
Gary :?: [/i:56537c9f8f][/b:56537c9f8f]
