On my front mount 8N im trying to prime the oil pump and have the plunger and spring out.
I can only get 1 squirt of 90w into the relief valve orifice before oil runs out the threads.
Is this amount usually sufficient to prime the pump? Also have a new spring; which is shorter than old spring - guess old spring was stretched?
Derek advised flat spot on plunger was normal.
Thanks for comments
Thanks for comments
