wheel weights
steve19438
just bought these
three plates for each side plus mounting plates and all hardware
seller has all mounting stuff.(bolts,etc.) plus six weights.
he says total weight is about 350/400 lbs.
I paid 400. probably should have tried to get em cheaper but since all the nuts and bolts are there....
good deal? probably not the best I've ever made. I did not want to fill the tires nor did I want something as heavy as pie weights.
I have filled tires on the rear of my 9n,and it gets great traction even in deep muddy swamps. They are very heavy when changing width of tracking.
I have removed allot of loaded tires on a N nuttin to it but the next one may get me.. As I get older if I loose it its taking me down with it I am sure... I would have held out for Pies you don't have to use them all....
The problem with loaded N tires are rear tires in general is Dipchits put to big a tire on'em...
