N8B
New User
Recently purchased 1948 8N. Purred like a kitten for several weeks then started misfiring and died. Sounded like ignition switch shut off when quit running. Was idling at time. During trouble shooting, discovered no spark at plugs. Also discovered 12+ volts at top of coil but drops to 8-10v when starter is engaged.
One by one replaced ignition switch, battery, coil, points, condensor, plugs, plug wires, ignition resistor, rotor, cap, and then all wiring running to and from. Same result. Still no spark.
Front mount dist with 12v conversion.
Ideas???
" Ideas??? "
Yes.
Troubleshoot the problem before you start replacing parts.
There are two schools of thought when it comes to getting a non-running tractor to start. One way is to just start replacing every part you can get to until it starts or you run out of money. The other way is to take a step-by-step approach to solving the problem, working from most likely to least likely. The trick to fixing these tractors (or trouble shooting any piece of equipment) is to be systematic about it. You need to isolate the problem step by step and work from most likely to least likely. You have solved half the problem by determining it is a spark problem. That doesn’t mean you need to replace all of the electrical parts on the tractor!
Assuming that the bushings & advance weights are ok (*see below), & that you have correct voltage to the coil (battery voltage with the points open and about half that with the points closed), the problem is in the distributor.
Once you get the distributor on the bench, the first thing you need to check is bushing wear. If the shaft has any sideways movement AT ALL, the bushings must be replaced. (*** see below).
The most common electrical failure (no spark, weak spark) points on the front mount are:
1. The insulator under the brass concave head screw & where the copper strip attaches. (it’s fiber & will wear out; poke & prod w/ your meter leads to make sure it still works) If you need to replace the insulator, use a .250 x 3/8 nylon square nylon anchor nut available at most big box home stores
2. The pigtail at the bottom of the coil not making contact w/ the concave head brass screw inside the distributor. (With the coil on, the pigtail must firmly contact the brass screw. No contact = no spark
3. The copper strip is broken or grounded to the plate. (look very carefully for cracks & breaks).
4. The condenser wire grounding to the plate or side of the distributor.
5. The tab on the bottom of the coil not making contact w/ the brass button on the cap. (With the cap on, the tab must firmly contact the brass button. No contact = no spark.)
6. Incorrect positioning of the spring clip on the plate causing the pigtail to ground. (the open part of the clip goes between 7 & 9 o’clock on the plate. That puts the straight part of the clip opposite of the timing screw at 3 o’clock)
7. Incorrect seating of the coil on the distributor due to a loose bail or no gasket.(the coil must not move at all; if it does, replace the gasket or bail. Or stick some cardboard under the bail).
8. Water/moisture inside the cap due to gasket failure or the absence of a gasket. (the cap AND coil have gaskets)
9. Dirty/corroded/burned/incorrectly gapped or misaligned points. I use only Wells, Blue Streak or Echlin brand points (* *see below). If you are using quality points and cannot get the gap to open to .015, chances are you need to replace the bushings.
10. Burned rotor, cracked/carbon tracked cap.
After you find the problem & re-check the point gap, do a continuity check before you put the distributor back on the tractor. Before you start, make sure your meter/light works.
With the distributor still off the tractor, follow these steps:
1. Coil off, cap off, points open. One probe on the brass screw & the other on both sides of the open points. On the side closest to the cam, you should have continuity. Not on the other side! If you do, you will also have continuity everywhere because the points are grounded.
2. Coil off, cap off, points open. One probe on the brass screw & the other anywhere on the body of the distributor. You should have no continuity! Now, rotate the tang on the distributor....as the points open & close, you have continuity (closed) and lose it when they open.
3. Put the coil on the distributor, cap off, points open. One probe on the lead on the top of the coil, the other on the cam side of the open points. You should have continuity!
4. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other anywhere on the body of the distributor. You should have no continuity!
At this point, I just put the distributor, coil & cap all back on the tractor as a unit. The reason I do this is because it is real easy to get the cap or coil misaligned trying to put it back together, one piece at a time. The result is something gets broken or you get a ‘no spark’ problem.
* Unscrew the plate hold down screw & remove the C clip to get the plate out. Remove the shaft & weights. The weights should freely move.
* *NAPA part numbers:
• Points: FD-6769X
• Condenser: FD-71
• Rotor: FD-104
• Cap: FD-126
75 Tips
when you are saying distributer off of tractor, is it just the cap or whole thing? I am having trouble with no spark out of coil and was going to try your steps
Take the entire distributor off. Remove the coil wire, pop the bail off the coil, remove the plug wires, take out the two bolts and it's off.
BTW.......
This only applies to the front distributor.
If you have a side distributor, do NOT remove it from the tractor. Post back for troubleshooting info on the side distributor.
75 Tips
Finally figured it out. Composite timing gear on cam shaft.
Wasnt turning distributor. Small section of teeth worn off.
Bought aluminum replacement gear. hoping f i get timing marks
lined up shell run!!!
