So was working in this tractor today. Put in new points from CNH and have spark but what is odd seems the spark will only spark as you let up on the starter button. It will not start either. Pull it 10 feet and it fires right up but does not run well. #2 and #4 plugs are wet when you try to start it with the starter and #3 is black and sooty. Opened up the carb that I had rebuild 2 years ago and was clean as could be. Told the guy to try a new set of plugs since these are 2 or 3 years old and let me know.
Any ideas as to why the odd spark problem. 12 volt conversion by the way. Compression is a tad low also. Been sitting about a year with out running. Did put a table spoon of ATF in each cylinder to help that
