8N 1948, 6volt front mount serial number 135902
I bought the expensive wiring harness from YT. Used the manual and instructions provided.
Voltage Regulator is a replacement. has B (battery) F (field) and A (arm). Checked made sure it was wired correctly. There was one remaining black wire that instructions said ground.
So, I attached it to the mounting base plate of the VR, connected battery and turned on ignition switch to start the tractor. Wiring harness started smoking melted the sucker.
Anybody know where that little black wire should have been attached to?
