8n brake return springs
Aaron WI
New User
My newly purchased 1947 8n came with a new set of brake pads and two brake return springs because the last owner ran out of time to install them. My service manual says it needs 3 springs (two on one side, one on the other) The New Holland dealer says I only need the two I have. Can anyone let me know how many I really need? Where I'm located, I have to order the parts, and returning will be difficult. I need the tractor, and don't want to take the wheels off and find out that I need a third spring and be stuck without it for awhile.
Thanks in advance for the help.
Aaron WI,As Delano nc said,You need 3 springs on the left side and 2 on the
right on a 8n ford.
Description: For tractor models 8N, NAA Jubilee. Replaces: 8N2027B Contains: Anchor (2), H2041 Adjuster Screw, 8N2217 Felt Backing Plate Seal, 8N2048 Adjuster Socket, 8N2223 Adjuster Nut, 8N2049 Adjuster Spring, 8N2297B Return Spring, 8N2299 Secondary Spring LH only. Brake Hardware Kit for 1 wheel.
Brake Drum Repair Kit Part Number 8NAA2250
