KCTractors
- Location
- Central Wi
I'm thinking about going to the round can coil from the square can. I seen one way was to put the condenser on the round can mount. My question is where do you run the condenser wire to with this way of doing it.
Another question is, if you take the distributor cap and drill a hole in the terminal ( on the cap)that would go to the round can coil. If the caps needs replacing you would have to drill a hole in the new cap again. Is there a better way to do this so if I sold the tractor, the next buyer would not have that problem.
