lock nuts for 8n piston rods
Mineola
New User
Is it necessary to order rod nuts from a tractor supplier or can you find them locally in hardware stores? Thanks everyone!
Mineola......are you askin' about them thin sheetmetal lock nuts??? I can gitt'em at NAPA ...or... corner hardware store. .......Dell
Minney.......generally, you RE-USE the rod nuts. Torque to specs and safety wire or thin (pal) nut them. Simple, eh? ......the amazed Dell
(quoted from post at 17:25:39 03/04/15) Is it necessary to order rod nuts from a tractor supplier or can you find them locally in hardware stores? Thanks everyone!
You will want hardened rod nuts and not the soft grade 2 - 5 that are in the common bins . Most rod nuts I have seen are longer than standard nuts and catch more threads .
You should be able to get better rod nuts at your local auto parts store . If my memory is correct , they are 5/16 fine thread like a 302 Ford . Blue thread locker will keep them tight .
