BlueLine9N
Alrighty then! Starting over with this 9N of mine from square 1; but I need a bit more of you Ford Tractor guru's advice...
First off - my alternator is SHOT. It has a 3 wire and the local junk yards around here arent likely to have any older model GM cars...with that in mind; what kind of alternator do I need to be looking for at the junkyard? I really dont want to buy a new one if I can avoid it since cash is tight at the moment.
Secondly - per JMOR's diagram; I need a diode to go from the 3 wire alternator to the resistor block...Do any of ya have the specifics on what the diode is as far as voltage, looks or whatever so I can attempt to find it as well?
Tanks in advance too!
