8N brake cover removal????
550Doug
Location
Southern Ontario
The 4 screws that hold on the brake cover of my 1949 8N are seized real bad. Is the best way to remove them is by an Eazy-out?
What are some methods other people have used?
Thanks
First soak them in Blaster liquid. I use a small chisel (screw driver might do) and tap on the outer edge to get it started. Once its moving, a large screw driver will extract it.
I use this impact driver to remove the after soaking with PB Blaster.
I agree with Del they work pretty good. Some ATF out of a pump oil can a hour or 2 before doing it will also help. If real bad a bit of heat carefully applied will help also
