Du Farmsabit
8N motor power plant for a combine, it hasn't run for a lot of years. Rebuilt mag, carb, new plugs, good wires, runs on either. I put some diesel down the plug holes to clean it, then put 10/30 after a few days. Brought compression up to 70,70,70,100. Still not sucking gas up into the engine. Royce said to use ATF, so i did that today, took the carb off, pugs out, put in maybe quarter cup of ATF in holes, and cycled motor a couple times.... My question,,, now what? Do i wait a couple days, let it soak, do i do this a few times, then maybe put oil back on top again? I am hoping i don't have to do a rebuild, but i will if i must. Thanks in advance.
