9n wont lift
cdv
fire up my 9n 1st time in 8weeks..3p[t wont lift or wont go down its stuck in can jump up and down on the arms which are about half way up there stuck solid wont budge a bit thanks cdv
How cold is it where you are?? sounds like some water in the system and it is solid ice and ice does not move
several years ago had 8n did that.tip broke off end of lever that moved valve.dealer wanted $189.95 for new one.welding shop fixed it for $5.00.finding tip in oil was worst part.
Ice. Wait til it thaws out and then replace the oil if it is milky looking. Hope you didn't crack the pump.
