For Royse..Rusty carb I mentioned
GB in MT.
[b:ec968446e7][i:ec968446e7]
LR;
Here is the pic. of the carb that the owner didn't want back.
SO....now it is going into the tank, for about a week, just to see if I can make it useful, as a back-up for Hermie!! I need a good used carb, to replace one that I prev. sold.
Lots of rust in this one, and has rusted off half-shell screws.
Just gonna waste my time.....MAYBE!!????? :lol:
OR...it just might buff right out!!!
Gary 8) [/i:ec968446e7][/b:ec968446e7]
Richard;
Gonna try my Best, to make ya go to work on yers!!!
Pike;
I'm quite sure the MacNaughtons will flow much before I get this one workin'!!!!!
Gary :lol: :p
(quoted from post at 16:07:29 02/27/15) Must need glasses, don't see a problem --for the Amazing Gary !! ;^)
b:60cab06115][i:60cab06115]
Bob H.;
What the heck.....are you back on the Prozack again!!???
Gary :shock: [/i:60cab06115][/b:60cab06115]
I have run into a few carbs about as bad as that one. Had one off a tractor that had burned and it is real bad and I have yet to be able to get he screws out to see how bad it is inside
(quoted from post at 17:53:44 02/27/15) [b:1e15d65638][i:1e15d65638]
LR;
Gary 8) [/i:1e15d65638][/b:1e15d65638]
asty, nasty!
Ouch! That doesn't look like fun to me! Hopefully the choke
and throttle rods broke clean instead of twisting.
Those bolts will be tough unless you heat them I think.
Although a good soak might do them some good.
Have you got pictures of the very worst one you've ever done?
I do not. I wasn't taking pictures and keeping records then.
(quoted from post at 18:30:16 02/27/15) Ouch! That doesn't look like fun to me! Hopefully the choke
b:5b2d67d8c7][i:5b2d67d8c7]
Yep....here is the one that gave me the most trouble, but was able to fix, and get it up and running!!
This is one of the four that I did for Carmine D.!
As far as I know it was running great,...as he said it was!!!!
Almost as rusty as the one in this post, but nothing major, other than the fact that it took 4 days in the soaker, and lot of scrapeing, blasting, and painting!!! 8)
GB[/i:5b2d67d8c7][/b:5b2d67d8c7]
I brought a 2N that had been dissembled and set out side for 15 years. The carb was in a coffee can full of water... It took me years of soaking with PB blaster to get the throttle and choke shafts out... About the time I got it close to were I could build it I put it back in a can and on the shelf...
May the rusty carb gods be good to ya...
