trailer tractor hauling
Wood I have used both and metal tend to be harder to drive up on and if you have a track drive machine next to impossible to load up. Metal if wet is even harder to load on to
Wish I had a metal one--no place to keep one inside so replace wood-rot out, replace, repeat, repeat
The treated wood on my trailer has been there for 10 plus years now and still holding up well and I keep it out side. Had one with metal and almost lost a dozier off of it.
Guess I just need to try to find decent, well treated wood. So much of it is half-treated these days..
I had a wood deck, still good after 15 years. Sold it to buy a bigger trailer. Just make sure your trailer is wide enough and as low to the ground as possible.
Neighbor bought a trailer that needed a new wood deck. It wasn't that difficult or expensive to replace wood. We did it in a few hours.
Used trailers are too expensive if you have to replace wheel bearings, brakes, paint, and especially if you have to replace tires.
I shopped around and bought new implement trailer that was bigger and heavier. Same with a dump trailer. A new trailer you getnNew tires and new brakes; worth the extra money. I learned that lesson when my first trailer was a fixer upper. It was a money pit, not to mention the old brakes pulled to one side. Do yourself a favor, go new.
i've used a wood-deck trailer for years. there's a reason why most commercial/industrial equipment-moving trailers have wood decks.
you can treat your wood with used motor oil, apply with a paint brush. it's inexpensive to use, and is effective in repelling water.
i use it on the wood dump bed of my truck, too.
Wooden deck has a couple of advantages.
It is lighter. Compare the weight to a steel deck that's thick enough to not get all dented up.
And as said wood deck is much less slippery.
The worst trailer I ever used had an expanded metal deck - the heavy screen type stuff. I hated that one as the chains would easily go through the holes but were a bear to pull back out.
Here is the trailer I have. I lift the front with a HiLift jack to tilt it. That's what I'm doing in the photo.
Wood deck for sure. I have 2 trailers. One is 5 ton rated the other is an old 2 place snowmobile trailer. Both are wood decks. Only problem I've had is the small one is a tilt bed and sometimes the golf cart or a garden tractor will lose traction. I've got some mesh to put down for tires to grab but just have not done it yet.
only in the near term following application. most of the oil is absorbed by the wood, and only a little bit remains on the surface (and only patchy). it either washes off in a rain event, or attracts some road dust to it which ends the slippery problem. as far as i'm concerned, the price (free) and protection (pretty good) outweighs a very short period of "low-traction".
also, in case it isn't clear, use rough-sawn lumber for the deck, not finish-planed wood. it not only has a rougher surface (offers better traction) it absorbs oil (or other protectant) better.
wally
One more tip:
When you park the trailer, jack it up so the deck is tilted slightly so rain can run off instead of puddling and soaking in.
