bentwrench54
hi everyone!
i'm converting over to 12 volts on the 8n here in the spring. i will be using a 12 volt coil, and a gm 3 wire alternator.
i want to be able to run a small sprayer for the garden, and also be able to use a strobe beacon for when i am plowing snow in the winter time. i also want headlights, a rear work light, and one red running light.
i want to place a fuse in front of any switches to protect circuits, correct?
thank you in advance.
